show msrp listeners
show msrp listeners {egress | ingress | ingress-and-egress} {port port_num} {source-mac-addr source_mac_addr | stream-id stream_id}
Description
Shows MSRP listener information.
Syntax Description
msrp Multiple Stream Registration Protocol.
listeners Listener attributes.
egress Display egress listeners only.
ingress Display ingress listeners only (default).
ingress-and-egress Display all listeners.
port_num
Filter based on ingress port number of the stream.
source-mac-addr Filter based on source MAC address of a data stream.
stream-id Filter based on stream ID of a data stream.
Default
N/A.
Usage Guidelines
Use this command to show MSRP listener information. The output can be filtered based on the stream id, source MAC, or port number on which the listener is registered.
# show msrp listeners
    Stream Id            Port  Dec       Dir      State       Stream Age
                                                 App  Reg  (days, hr:mm:ss)
00:50:c2:4e:d3:2d:00:00     19  Ready    Ingress  VO   IN       0, 00:58:12
00:50:c2:4e:d3:2d:00:01     19  Ready    Ingress  VO   IN       0, 00:58:12
00:50:c2:4e:d3:2d:00:02     19  Ready    Ingress  VO   IN       0, 00:58:12
App      : Applicant State,                Dec     : MSRP Declaration Types,
Dir      : Direction of MSRP attribute,    Reg     : Registrar State
MSRP Declaration Types:
AskFail : Listener Asking Failed,          RdyFail : Listener Ready Failed,
Ready   : Listener Ready
Applicant States:
   AA   : Anxious active,                  AN      : Anxious new,
   AO   : Anxious observer,                AP      : Anxious passive,
   LA   : Leaving active,                  LO      : Leaving observer,
   QA   : Quiet active,                    QO      : Quiet observer,
   QP   : Quiet passive,                   VN      : Very anxious new,
   VO   : Very anxious observer,           VP      : Very anxious passive
Registrar States:
   IN   : In - Registered,                 LV      : Leaving - Timing out,
   MT   : Empty - Not Registered
This command was first available in ExtremeXOS 15.3.
Platform Availability
This command is available on all platforms that support the AVB feature and that have an AVB feature pack license installed. To see which platforms support AVB and for information about obtaining a license, see the Switch Engine v33.1.1 Licensing Guide .
